Makdaddy
I am Dysfunctional
Hope that got it
Good Luck and what a bitch of a problem
Hope that got it
No kidding!
Stupid aeromotive pumps.
The 340 is not enough pump for your car. A few others have tried, just not enough. Surprised it has been on the road that long like that but glad Greg got you hooked up!
Dept of Boost should update their "unofficial" install guide to recommend the Walbro 405 or 465 instead of the Aero 340 for the GT450 mani kit.
I did not catch that they put that in there but yes it needs to be changed. I remember placing it on the "unofficial guide" back before the manifold was even on the market but testing proved it was not enough. There was a bunch of discussion on the topic back then so not sure how it ended up on that instruction page. Sorry you went thru all that based on information found there.
One thing you've sure gotta be thankful with these cars is not having to drop the tank to replace the pump!!
This is slightly off topic but ive been having fuel pressure issues lately and i didnt want to make a new topic... I have the GT500 pumps and have recently gotten into drifting and ive noticed that my fuel pressure drops after changing direction during long drift sessions and usually when im drifting left corners, at first i attributed it to having low gas but after filling the tank the issue still exists. I havent been able to figure out the pattern of when it happens but sometimes when i monitor the fuel pressure gauge at idle or when cruising on my aeroforce gauge ive noticed that it ranges from 39-40 constantly but would sometimes randomly flash 0.00 for a split second before going back to normal.
Im running 7-8psi (8-9psi pulley) on a 2.3l Whipple with GT500 pumps. Ambient temps where i live are between 110-125*F.
Should i be worried? Is there anything i should do? Could it be from the heat? (pumps overheating?)
datalog.
You'll see at the beginning of this thread that I was stubborn about the datalogging, but it ended up being my best friend!! It really helps to be able to see what's going on.
^^^^ This
datalog.
^^^^ This
Just checking to see if everything is still good. Make sure you have the wire/relay with that walbro 450 pump and I wouldn't use the bap with it at your level. Just gonna add unnecessary heat. How is your pump attached to the plastic T fitting now? I saw in older pics the hose was down low on the barbs and attached with a worm gear clamp over the barbs, that can lead to leaks or it slipping off. Make sure the hose from the pump to the plastic T Is full seated all the way past the barbs and you use a fuel injection hose clamp like you used for the pprv delete. Place the clamp above the barbs clamping the hose tight this will provide a solid leak free connection.
^^^ think he lost the motor unfortunately.. http://www.s197forum.com/forum/showthread.php?t=109614
Ruroh...
Looks like I have the same FP issues, although I don't have to travel 100+ miles for it to occur. It's there, all the time now.
