Makdaddys S&H Turbo Build ( SLOW)
weather man
Persistance Is A Bitch
MN
I put the Ford Racing fan on to give a little more room. Hopefully, I can report results next week.
Makdaddy
I am Dysfunctional
South of Chicago
Brian
That would be great I was also considering that fan option
Im curious to hear about your results, u still running Zimmers hot side right
How is the build going?
Makdaddy
I am Dysfunctional
South of Chicago
i haveng had thd plastic piece that goes under the radiator from the bumper to the radiator support since I put my turbo kit on
Thanks Josh
that rules that out
My fans are rated at 1250 CFM each
is that about the same as the dual setup u are running?
weather man
MN
Brian
Zimmers hotside with a dual wastegate setup. .Piping is done and may repowdercoat, depending on leadtime. Hope to have on the dyno next week.
jodadejss06gt
TEAM DELETE SHIT
Severn MD
maybe pull the screw off the top of the crossover pipe going into the engine and make sure fluid is all the way up into the threads and then once it is put it back on.
Makdaddy
I am Dysfunctional
South of Chicago
Well new driveway is in deck around pool is in
All of my Honey Do house crap is done.
time to finally get back to the car
Will get it back together and hopefully get the running hot issue correted
So pics of intake and new rad cover
My son painted these last night
[U
Makdaddy
I am Dysfunctional
South of Chicago
Good luck. Been wondering about this build
Yes. Good luck sir! Glad you're making progress again.
Looks good.
Thanks Guys
Im glad Im back on it
But Ill admit If I cant figure out the heat issue , ( Hot when AC is on)
Well I donno what Im gonna do.
I have a Riesch 170 T stat going in, Ill be looking at all of the hoses for Flow issues, and my last ditch will be to put that stock GT500 Fan and shroud in.
If that dosent fix it, Its beyond my scope of experience.
Waiting for weather man to chime in On how his temps are running after his build, I think he went to that shroud and fan as well
Makdaddy
I am Dysfunctional
South of Chicago
You should have powder coated it. It has less chance of bridgeing the gap on the fins.
Well Crap I think its gonna be ok. My Iat's were always pretty decent we will see
With the piping painted it is going to look sick.
Thanks
I need to get it all squared away, we have more to paint under the hood, but I wanted to get it on the road and figure out the cooling issues
It's never really done lol
