Square setup ftw! Otherwise you'll be trying to tune out understeer with other components.
On a fully-prepped car like Marc's or Terry Fair's, you actually want more rubber in the rear.
(That's what she said.)
In his case, I think a set of F14's is exactly what he needs...The F14's are also blatantly Forgestar, something that is important to sponsors...
Irony then that Terry has been running a square 315 setup (admittedly until recently on 18x11 fronts and 18x12 rears) since early last year when he ditched 335's, or was it 345's, out back for 315's because of the god awful push his car had and couldn't get dialed out.
In his case, I think a set of F14's is exactly what he needs. IIRC the F14's are one of the lightest wheels Forgestar makes and for his car, lighter would be far better than something that "looks" better but is heavier. The F14's are also blatantly Forgestar, something that is important to sponsors...
Congrats on the sponsors although I would stick with a square wheels/tires setup all around for a track car, but that's just me!
The stagger is only 1" in width and that is easily overcome with spring rates and sway bar settings. I like as much front and rear tire as possible and then make adjustments as necessary. There are two reasons why I want more rear tire.
1: Increased traction and being able to accelerate harder out of 1st gear corners. With the 11.7" wide slicks that I currently use, I can't get close to exiting a 1st gear corner at full throttle.
2: Due to the rear wanting to lose traction under hard high speed braking. I'm a late braker and I want as much rear tire as I can get.
It's true that a loose car is almost always faster than a tight one. Coming from driving a championship winning Carrera, I too prefer a car on the loose side. However, this car has over twice the power of the Carrera and better weight distribution too. If nothing else, the HP and trail-braking will assist me in putting the car into understeer or oversteer at will. If the car is setup loose during zero throttle input, then the ability to trail-brake is diminished. I believe that this car won't like to be loose but we all know that a overly tight setup doesn't work either. My plan is to try and set the car as neutral as possible and then use the power as needed. If the stagger doesn't allow for a neutral chassis, I will keep adding spring rate and see what happens.
One thing is for certain, getting everything right the first time won't happen. I'm sure that I will have to play with different spring rates, shock settings, swaybar settings, and tire pressures until I figure out what the car likes and what the different tracks like. I have at my disposal, one of the leading chassis crew chiefs that has worked for a few pro teams. I plan on having him with me during private track sessions while we get everything sorted out.
Makes sense, just watching the build come together and seeing the videos and news reports on it...just would be disappointing to see it on the same rims everyone else buys from American Muscle..
Received confirmation that the custom KW coilovers actually shipped yesterday. For a baseline, I went with 570lb springs in the front and 340lb springs in the rear. Not sure if this will be where I stay in regards to spring rates, but it will be a start.
As soon as I get the coilovers installed, I can then measure backspacing so I can get the wheels ordered.
I have been working with a few designs on the wrap. however, the design team hasn't presented me with anything that I like. So far, everything has too much of a drift car look.
