I thought the FRPP bar was larger than stock?
Thats pretty much what i thoughthe front on stock GT is 34mm, FRPP is 35mm. rear on stock GT is 20mm, FRPP is 22mm.
This will really depends on what you are looking for. Drilling out the stock bar will essentially give you bigger bar, you are changing (shortening) the pickup point of the bar so you will get the effects but not as much of a larger sway bar. It is a good grassroots solution but may not get you where you want to go.
What are you trying to solve handling wise that you believe you need a larger bar?
Fwiw I run my front bar full hard and my rear bar full soft. I'm running HELLWIG seas though and I know that the shoreline is an odd rear bar and mound to the axle. Are you staggered?
