Wicked One
For those who want to save some cash and not relocate the battery to the trunk. The moroso reservoir can be mounted where the factory airbox was.
I did this for my kenne bell that has the intake routed on the passenger side.
Tools:
1/4 drill bit
7/16 wrench or socket
drill
Parts:
moroso or equivalent reservoir
factory battery hold down
optional bracket ( I used the kenne bell bracket for the washer fluid)
1-1/4-20 x 3/4
1-1/4-20 x 1.5
2-1/4-20 nuts
very easy. Lay tank in factory airbox location with it placed with the mounting tab against the brake distribution box.
place the battery holdown on the opposite end and mark the hole.
using the drill, drill the hole.
now simply lay tank in, and bolt the hold down using the 1.5" nut and bolt.
The optional support is bolted to the factory hole for the airbox.
I am not good at these DIY's. so look at the pics.
Hope this helps
Tools:
1/4 drill bit
drill
Parts:
1-1/4-20 x 3/4
1-1/4-20 x 1.5
2-1/4-20 nuts
Hope this helps
