mbreinin
Mine squeak from time to time. I just chalk it up to having a set of high performance brakes and pads on my car. My STi, which also had Brembos, was a squeaker as well.
Mike
Mike
So taking the Brembos through a 'bed-in' cycle doesn't get rid of the squeal?
I've been told that to properly bed-in new pads/rotors you perform 10 stops from 35 mph to rolling speed, taking 3-5 seconds to slow from 35 mph and driving for one mile between brake applications. It is critical that you do not stop completely as you will leave a rough spot where the pads stick to the stationary rotor.
The purpose of these 10 stops is to heat up the brake system and transfer pad material to the smooth rotors, giving the pads something to work with/get traction on.
So does this process improve the symptoms for the Brembo owners?
I had always read this was supposed to be done at a higher speed, like 60. 10 60-5 brakes of increasing intensity is what I have always done.
Perhaps they are saying lower speeds so people don't break the speed limit doing so??
