So the saga continues. Shop finally goes to put the crankshaft in, spins it, doesn't feel right. After some investigating, turns out the crank is slightly bent. So its off to get re-ground. Also it turns out as I'm told that the "brand new" crankshaft MMR is advertising is actually a forged crank from something else thats been turned down to work for the 4.6 engine. (the 5.0 mustangs?, idk) So its a new take off, so I guess thats kinda new in a sense?
Anyway, I've been told that its not uncommon for crankshafts to end up bent due to stress relief over time, but like wtf if they are grinding the crank now the main bearings that came with the MMR kit are going to be no good so I'll need an undersized set right?
Maybe the shop is just going to use a press and give it a little nudge back into tolerance. Going to call and ask.
sigh
