Need a part number...
Jgt58
Does anyone have a part number for a factory positive and negative battery cable for a 14 5.0 without premium brakes? Manual trans?
Jgt58
I can't seem to find it ...
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Send a message to Steve Powell, he is a vendor on here under Tasca Parts, he is the wizard for Ford parts.
tjm73
of Omicron Persei 8
Rush, NY
It's easy to be a wizard when you can open up the program that dealers use to look up part numbers.
Jgt58
I'm thinking the part is all one unit. Positive and negative together. That's all I'm seeing.
JEWC_Motorsports
S197 Junkie
Texas
Ford does not sell the negative by itself, its included in the 14300 positive harness.
The battery cables are part of the trans harness. It was around $180 for the harness when I built mine. Includes the epas wiring.
JEWC_Motorsports
S197 Junkie
Texas
Im guessing the end crapped out. That happened to me and i ended up just cutting the end off and soldering on a new ring connector. Used a marine style negative battery terminal so i could disconnect the battery when the car sits for long period of times.
Jgt58
No looks like corrosion has made its way down the terminal into the wires.
