It's usually cheaper to buy new then rebuild one of these pumps because of all the corrosion involved. Did you remove the front basket assembly or is it a separate unit on your setup? On all the Hayward pumps I have used, the basket assembly is part of the pump package. You should be able to find a replacement within your budget.
Earl
