superslow86
^ Congrats. I want to make the flex jump soon! Pics?
is it really so much better than the pc. i know the price difference is huge, but it really worth it.
Hey Seer anything different on your Race Red formula for a Kona Blue car?
Seer,
I have been lurking and searching on this subforum for a few days and I have a few specific questions.
I have a 13' Ruby Red Vert. It has not been polished, sealed or waxed since purchased a few months ago. From what I can see in sunlight there a few light swirl marks from improper washing. I will be performing the process you have outlined in this thread and using the 2 bucket wash method with grit guards.
1. Should I use a CG citrus wash initially to get the paint prepped for polishing, sealing, etc; and use the maxi suds II for normally washing in between full detailing?
2. Is the Meguiar's 105 and orange pads too much for light swirl marks?
3. And if so, what should I use?
4. The clay bar lube you recommended is out of stock, do you have a recommended alternative?
5. Will the backing plate you listed work with the porter cable 7424?
Thank you for your help
David
Thank you for the great direction.
I don't have Lake Country pads, or any at that, so I will order some. Excuse my lack of experience, but the crimson pads can be used for applying the lava and black light?
Also forgot to ask another important question. Convertible top: What is the best product and method to cleaning you recommend?
Thank you a whole bunch!
This is everything I need to get started. I will post some before and after shots.
