Redrocket06
Car started and drove fine to work and back home. When I got home I forgot to cancel out of the datalog I was doing on the SCT, not something I haven't done before. I was on graveyards so I got home around 7am, at 4pm I went out to start it and it had dashes on the mileage readout and then it changed to 'check charging system'. The pump never primed and keying to start did nothing, no click, nothing. Checked voltage it was 12.2, jumped it off of my truck with 14.2v and had the same results. I checked all fuses and relays on the BEC and SJB, blew them all out with air to look for moisture getting in them. Now the strange thing it I can plug in my SCT with the FireWire that lets it read my LC1 and it will start but run real rough and the pump volts read 0 to negative 2. After fiddling with the fpdm it lined out, turned it off and restarted with the same rough idle and messing with the fpdm did not help this time. I tried a different relay than the one that came with the pump wire upgrade, no change. If I just plug in the SCT without the FireWire it will not crank. With the key on and only the sct plugged in the sct will not power on unless the firewire is connected, key off it will power on without the firewire. Also tried starting with maf unplugged, all gauges unplugged from 12v power, same thing with needing SCT plus FireWire to start and run like crap. While running, unplugging FireWire results in engine turning off.
Tomorrow I want to pull the battery and alt for testing and unwire all my addons that the car doesn't need to run and see if something is grounding out.
Any ideas will be helpful.
