- Joined
- Feb 2, 2010
- Posts
- 1,479
- Reaction score
- 0
Hey fellas, got a question for those that may of had or have a noisy 3650. I swapped out my clutch about 3 weeks or so ago and it was perfect for about a week. It then developed hard shifting into 2nd and 3rd at higher rpms. Thought it was the slave, re bled it. No change, but then I noticed the noise.
I had initially filled it with Lucas Oil's equivelant to Mercon V with a half bottle of their trans conditioner. Drained it out, filled it with Motorcraft Merc V, no change. Drained it and now running Penzoil Synchromesh fluid (didn't feel like spending $18 a quart on Royal Purples stuff), and it does work a little better.
I know the trans is in need of an R&R now. I'm sure it's the synchros and a bearing making noise now. Kind of my fault on that also. I never did a fluid change on the trans in the 140k miles that I've put on the car. It kind of sounds like my old GForce T5 with straight cut gears I had in my old Fox 5.0.
Guess my question is for those of you who have or have had a noisy 3650, how long did it last or how long has it lasted since the noises came to you? I can't afford a swap, nor even a rebuild at the moment. Just trying to gauge how much time I may have. Thanks fellas.
