Noisy, creaky brakes...?
RoushTang11
West Palm Beach, FL
I recently did a brake job, rotors and pads. After doing so, my brakes are noisy, making a creaking sound like it's the calipers moving or something? I have good tension in the brakes, they're not soft or anything like that, you can just hear them closing. Could I have gotten air in the time or something like that?
Note - this is NOT a squeal or squeak - it sounds more mechanical.
did you check the caliper pins?
I suggest it as I’ve had issues 2x on another Ford in the last 6 years
Expat
Did you find out what the creak was as I’m having a similar sound
JC SSP
FL
Not sure if you have Brembo's, but on regular Mustang brakes... It is essential the caliper guide pins are cleaned and properly lubricated with hi-temp brake grease, since they are a "floating" design. Also, all contact points where the pads touch the caliper be cleaned and a lite coat of grease or anti-squeak (orange paste) applied.
I use brake cleaner and a plastic gun bore bristle brush to clean out the guides.
Good video: How to Replace Front Brakes 05-16 Ford Mustang - YouTube
I am assuming you torqued everything to specs, used quality parts and used and/or replaced any clips where the pads slide into.
Also, don't forget to do a proper "bedding" procedure of the new pads and rotors... I don't think it will cause the clunking noise, but pads and rotors perform much better.
