Fallenauthority
Been known forever, still doesnt change the fact that you are fucked it it was tuned.
Well you don't know that for sure
And if it is I feel bad fir the z06 vetted running around because I will be built
How long has this been happening? Because my 06 was returned to stock and fixed under warranty several times lol
Not the case with the new 5.0Maybe not all dealers are like that. I once took it to the dealership and asked them if they check for that, the svc manager said unless they have to reflash the pcm they don't bother with it..
Ford released a TSB specifically stating that if the PCM was ever flashed other than factory, warranty is VOID.
Trust me, they check. Might not have cared on the old 4.6's but on the 5.0 they do.
i dont think you can go .030 on the new 5.0...i think .010 is about it.Ok so I hit wot and brought it to 6k rpm and then idle into the driveway and shut it down
A cloud of white smoke followed
I pulled out all the plugs
All the ends looked perfect (yes I know how to read plugs)
The ONLY thing i found was the #8 had oil on te threads and no other plug did
I know either #8 is scarred up or the rings aren't sealing
I'm bone stock now and at 4350 miles
I'm bringing it to ford next week
If they determin it was my fault then I am going to rip it apart and replace te rods an pistons with forged
.030 over and since I have it apart I will probably do a mild port job on the heads
I plan on keeping the same compression and running the rebuild on the stock tune if everything checks out unroll the rings seat and then I will be doing hellion turbo
If ford fixes it imbgoing strait to the turbo lol
Nope, no luck for you sir. Dealer considers 1qt every 1000 miles to be acceptable consumption. So until you are spending more $ on oil than gas, they will tell you to kick rocks, especially since you are tuned.well, its official. my 5.0 eats oil. Me and my buddy who works at a ford dealer who changes my oil have been watching this for several oil changes now, its uses 2 quarts every 3k . The only time I actually notice smoke is wide open shifts close to redline but I dont do that very often. Car runs awesome other than using oil no complaints at all but it does have a tune and cold air, o/r X....since its seems thats most likely not a #8 issue ( or would it be????) any hope w/ dealer regarding issue?????? cars got 23k miles on it , its used oil like this from the start....high break in use never stopped. It wasnt tuned until 14k miles
