AndrewNagle
I am having issues with my oil pressure being too high, I think I have a damaged oil pressure release valve in the pump (from oil relocation kit installed incorrectly) I am getting ready to have the oil pump changed out.
This caused me to do some trouble shooting and I undid my dual sending unit setup that was all 1/4" npt brass fittings (male to male, T and 90 elbow)
I wanted to use -an fittings so i could swivel the joints and have easier access to the sending units. I am going from 1/4" NPT male to male to -6an elbow back to 1/4" NPT "T " (since the OEM sending unit is 1/4" npt)
Now the OEM oil pressure sending will not register any pressure when using the T and an fittings. But when it is placed directly into the engine it works. I am splitting so I can use an Auto meter electric gauge that works in both cases.
I have ordered a new sending unit and 1/4" NPT elbow and 1/4" npt "T" so I can stay away from the -6an (i can't reuse the original 1/4" npt brass male to male cause it got damaged removing it from the engine, it did not have a nut in the center, used vise grips to remove it)
Any ideas ?
Thanks
Andrew
Any ideas ?
Thanks
Andrew
