VTXFrank
Obama SUCKS!
i think your nuts till you get a better gauge on it.......even if its just going to the auto parts store and getting a cheap mechanical gauge just to test with....
I agree. This is one of those things where if you run the motor and burn it up knowing the oil pressure is low, the builder is going to tell you to break out another $5,000 bill. They aren't going to fix it if it blows up if you keep running the motor with that low of an oil pressure.
As mentioned, get a mechanical gauge in there ASAP! Could be the adapter you built is your problem. But until you know for sure, stop starting the car! Much less driving it!
