shifter87
"Go Big or Go Home"
Wow usually the first runs are faster because the car is so much cooler although I have had days like that. What LCA/UCA you running.
Summit has UMI on sale for like 90 bucks. I was gonna go with that.
Turbos run better when they get hot
correct, you want cold air entering and cooler engine temps but want that turbo hot for a fast spool, which is why you do things like ceramic coat the hotside piping and header wrap and turbo blanketsI am still stuck in N/A phase But I figure cooling down the motor wouldn't hurt either.
Air pressure and volume spools a turbo not heat energy. The coatings keep the heat in the tubing so that it exhausts the engine bay.exactly ^
hmmm... interestingAir pressure and volume spools a turbo not heat energy. The coatings keep the heat in the tubing so that it exhausts the engine bay.
http://s197forum.com/forum/showthread.php?p=519876#post519876
sweet deal man, I'm going to our local 1/8th mile on Saturday and should have some times... probably looking to upgrade from the 3000 to a 3600 stallJust to give you guys some hope with the turbo. I went a 10.79 @ 126 at 9psi last week in 85* weather. That was through a 4R70w on the transbrake though.
But those of you guys with the 5R55 and a decent stalled converter will probably be going faster... The stick guys a little slower cause you cant really leave in boost and will have to power shift the car to stay in boost.
Wow thats some good times man. I went 12.2@115 so far with a 2.0 60'. But I'll be doing to a good track friday. Then I'll intall my clutch, LCAs and the WOT and go back out again. I'm hoping to run 11.6s and I'll be happy.
i can leave in boost. i have the wot box and @4000 rpms i make 10psi.
