twilson1918
- Joined
- Feb 26, 2009
- Posts
- 263
- Reaction score
- 0
Well the other day its was about 90 degrees outside here in indiana i was in stop in go traffic and noticed the car was creeping up in temp it got to the point i had to pull over. I let the car cool down started it back up and barely got home i drove it the other night to work i work 3rd shift so it was obviously cooler outside and it never went above midway on the the temp gauge. I drove it around after work as the temperature outside rose and it never overheated, I came home turned it off started it back up and took off again then it started overheating. It seems if i restart it after the engine is warm it wants to overheat. I have a Paxton Novi 2200, the coolant level is good, fans are running, any ideas on what it could be i was thinking maybe stuck thermo but wanted to get some opinions Thanks Guys!
