Darkside323
The HID Harness you have for sale. Is this the factory unit? Will that hook up to my 07 with non-hid headlights? What else would I need to make it work?
I got the drivers side off, but haven't pulled the passenger side yet. Give me another day or two.Window trim?
The HID harness is the factory headlamp harness for an '08 with HID's. To add it to your '07 you just need to swap it out, and as I understand, repin one or two pins where it connects to the fuse box There should be a thread or two here about how to do it. The only other things you'll need are two OEM HID headlamps.The HID Harness you have for sale. Is this the factory unit? Will that hook up to my 07 with non-hid headlights? What else would I need to make it work?
Which a/c parts specifically do you need? The headlight harness is the HID harness. It's all integrated into one harness. I have the brake line and hose.What's the best price on the ac parts, factory headlight harness not the hid harness but what the hid plugs into and brake line from the abs module to the pass. Front brake hose. Shipped to 87109
Only the drivers side survived. It's nice. I do have a nice pair from my '05, but I'll be listing those with a complete black interior set.Door Pannels Decent?
The alternator is sold.Alternator still available? Shipped to 32561?
I have the compressor and most of the lines. The line that attaches to the condenser on the passenger side was damaged. I have all the other lines. Some of the lines might be tricky to ship. If you're interested in them, I'll get them together and see what sort of box might be needed. The trunk trim panel and tire cover/carpet was also damaged.Compressor and all the lines except the one that bolts to the firewall behind the intake. I also need the trunk interior panel the rear most that covers the taillights and latch striker. Also the carpet and spare tire cover.
Yes I have that. There's no wiring with it though. It's just the aux plug that snaps into the console housing. $20 shipped.How about the aux plug in from the console if it had one ??
I don't. They were smashed on both cars. I'm actually looking for one myself. I modified my own for my Snow Performance kit, and I just pulled that kit off, so now I need a bottle.Do you still have the wiper fluid bottle assembly?
$75 shipped. It's a little warped, but a heat gun and a little time should work it out.
Do you still have the fuel pump assembly ?
Hey not sure if you have it still the plastic lever to recline the seat forward on that back of the seat?
Sent from my SCH-I535 using Tapatalk 2
Drivers side cam sensor AND harness?
Sam, you getting caught up on this now that your car is done?
