snopro442
Ok so after a lot of messing around and countless hours I still have toe out on the passenger side front wheel. I tried to move the steering rack and that's a no go. When I installed the k member I left the tie rods in the spindles and did not touch them so that is not the issue. I removed the BMR a arm and installed the stock arm and still the same problem. So I put it all back together and took a few pictures of it. The first thing I did notice is the drivers side 2 mounting bolts at the rear of the arm are both even and towards the front of the car (see picture) the drivers side is all nice and straight and it all looks great. Now when you look at the passenger side rear 2 mounting bolts you will notice that they are not even and the one outer bolt is more towards the firewall and the inner second bolt is towards the front of the car. With the a arm out of the spindle it does move nice without any binding. So my question is, is the k member twisted? I took a few pictures of where the k member mounts to the 4 bolts that hang down from the frame and you will see that they k member is mounted towards to firewall and looks even. Again any input would be great Thanks.
