Pilot bearing
ghunt81
New parts on old junk!
Clarksburg, WV
This might be a stupid question but why is it that most pilot bearings (including the one in the clutch kit I bought) come with the large metal "shell" or whatever it is that the bearing is in, even though it's not part of the bearing-but a few don't? I thought standard procedure was to replace the whole thing, but watched a video earlier where they just pulled the bearing itself and replaced it. Also asking this because I'm using a slide hammer, the bearing itself popped right out but the shell won't budge. I had to order a puller to get it out.
ghunt81
Clarksburg, WV
That's news to me...….
What video did you see that showed this as I'd like to view it.
These guys put the new flywheel on, then pull out just the bearing and replace it which I thought was kinda weird.
And I'm talking about a pilot bearing.
Bushing holds the bearing from Ford it's a single part. No special tools needed (other than a piece of bread or grease lol) to replace the whole thing. Thats dumb I would never do it that way. Also would never use a impact on flywheel bolts going into the crank.
