Battery Disconnect Switch
Relocated the battery to the trunk back in March 2013 and have had the disconnect switch for almost as long. Just getting around to installing the Flaming River Disconnect Switch part number FR1003-2 now.
Removed the trunk carpeting and rear plastic panel.
The disconnect switch will be centered in the back of the tire well with the push-pull rod exiting the lower section of the GT/CS bumper cover under the license plate.
Positioned the disconnect switch mounting plate and marked the three holes for drilling.
Center punched the hole marks and drilled them progressively 1/8, 1/4 and 23/64 to work with the ¼-20 blind rivets to be used to secure the mounting bracket.
Premiered the holes and installed the three 1/4-20 blind rivets.
Installed the mounting bracket and disconnect switch.
The 1 gauge positive feed to the Fuse Panel/BEC and Starter was rerouted from the battery distribution block (200 Amp fuse) to the disconnect switch.
A 1 gauge feed was routed from the other side of the disconnect switch to the battery distribution block (200 Amp fuse). This was to where the feed to the engine compartment was removed.
When the disconnect switch is “pushed-off” power from both the battery and alternator will be cut from the Fuse Panel/BEC and Starter.
Easy part is done, now to drill the back panel and bumper cover. I am keeping my fingers crossed!
