Kaldar142
Whats the absolute widest wheel width/offset i can run in the rear and front?
I could be totally wrong, but in order to run a 10.5" wheel upfront based on how my 10" sits with a +41 offset, i would need +30 or lower, right?
i want to get a custom set of CCWs or Fikses (or some high-end wheel) and run the widest possible setup, ideally it would be a 10.5" front with a 295 or 305 and 12" wide rear with a 335. I will most likely be running Nitto NT05s (love this tire!!) What offset would i need in the rear?
At the same time, i realise i could be setting myself up for understeer, but wouldn't i be able to dial it out with suspension tuning? Not to mention i am running -2.6 camber up front...and i have a blower. This car is a street car first, track car second. I plan on having a ton of power in the future, so putting some wider tires out back may be beneficial for me.
I also want the wheels to be extremely aggressive looking... poking out a bit, but not like a whole inch poking out, the fronts are crucially cambered in so i feel it won't appear to be sticking out that much.
I've been reading around, and someone said 18x10.5 +50 with a 13mm spacer fits upfront
Someone has also said that a 18x10 +40 with a 9mm spacer will fit 315/30s upfront
Thoughts and opinions please?
Also;
Thoughts on running a 295/35/18 on my current 18x10 +41s all around? Right now my 285/35s seem to be an almost perfect fit but they dont sit 100% square with the wheel, i think i would be able to jump to a 295 and not have it bubble. The 295 would be nice for added traction, running 3.90s and 467whp can get squirrely sometimes.
The wheels i'm looking at are the CCW classics in black, CCW SP500 in polished or gloss black, Fikse Profil 10, Fikse FM10... also open to other suggestions
Also;
