tnsaleen
So in order for my turbo kit to be routed the way I want, the hard lines on the rack and pinion must be re routed. I took the lines off to look at the fittings and flare, and I don't have a flare tool that can create the same flare needed.
Below is a picture of the line and the flare, and then a regular line I was planning to use and bend to make work.
Does anyone know where I can get fittings to run a braided line, or know of a tool that I can use to make the same flare?
The regular line
Sent from my XT1254 using Tapatalk
The regular line
