Power steering line help!
tnsaleen
Nashville, TN
So in order for my turbo kit to be routed the way I want, the hard lines on the rack and pinion must be re routed. I took the lines off to look at the fittings and flare, and I don't have a flare tool that can create the same flare needed.
Below is a picture of the line and the flare, and then a regular line I was planning to use and bend to make work.
Does anyone know where I can get fittings to run a braided line, or know of a tool that I can use to make the same flare?
The regular line
Sent from my XT1254 using Tapatalk
tnsaleen
Nashville, TN
The flare is flat on both sides on the factory lines. Will this flare it the same way?
09mb5854
Harrisburg, PA
Here in central PA, we have a few vendors that will use the existing ends to build a hose (braided as an option) to any length that you want..... Most of the commercial truck facilities have hose building capabilities. That is where I go to have mine made for my projects.....
