tached_out
Bigger the better
- Joined
- Feb 22, 2008
- Posts
- 365
- Reaction score
- 3
I have a 3.70 pulley making 13psi. I getting some belt slip and some serious squeeling going on that never happened before.
I have removed all my pulleys and check the bearings and checked out my belt. It appeared fine to me.
I am sick of this sound because it is just getting worse now and at idle is louder then the blower and you know how loud out blowers are.
I plan on going to a billet idler pulley, new belt and a billet blower pulley.
My question is what size idler pulley should I get. Because when my belt is tight that brass bolt is so tight that the screw going down is about half way through the brass bolt and this just does not seem right to me. If I back it out like procharger say to for the recommendation tension I get slip.
I was thinking if I get a 100mm idler pulley the larger pulley should take slack out of the belt and allow me to not have to tighten my tensioner as far.
Also what is the best belt to get?
