I can certainly see it removing a wear item from the car!
However, I don't see how it's going to actually reduce the push you get around the turns. If anything, I'd expect it to increase the grip you get in the rear because now you're more properly balancing the power to the rear wheels.
My neophyte impression, for what it's worth, is that push (understeer) versus oversteer is always a question of which end breaks traction first. Nothing more, nothing less. If you dial in less understeer, you wind up dialing in more oversteer automatically. You may wind up also increasing the total amount of traction you get before something breaks loose, of course, and that's desirable, but in the end, once you get to the limits, one end or the other is going to let go.
You may end up having to give up a little traction in order to gain a bit of extra controllability. Ideally, you'd gain both simultaneously. I don't think a Torsen is going to accomplish that. It seems to me that you need to do something to increase the grip at the front end while keeping it the same in the rear. The Torsen should help with grip in the rear when powering through and out of corners, but won't help with grip in the front. Indeed, it may actually slightly reduce your grip in the front.
My reasoning behind that is that by more properly distributing the torque between the two wheels, the wheel on the outside is going to be getting more torque than it did before. That will cause the outside front tire to lift a little more, and thus to break traction a little earlier than it did before. Hence, I would actually expect more push with a Torsen than with the Traction Lok, both because the rear won't break loose as easily (thus, higher grip in the rear) and because the front will lift just a little more as a result of the greater amount of torque in the rear and, especially, on the outside.
Be interesting to see if my thinking on that is correct...
One thing you are leaving out is the thrust capabilities of the tires with a Torsen. When the wheels move at different speeds but off throttle the diff is "open" and when you apply throttle it will start to torque bias. Basically the outside wheel is going to receive more torque because it can support more torque and it will grab and move the car around the corner because the outside wheel is seeing greater power than the inside and is making less grip than the inside. With the clutch based diff it resists this motion so you'll get power on push (due to the added grip) all the way until the inside tire gets enough power to spin and then it will try and lock both together causing throttle oversteer.
I have yet to hear someone say a Torsen causes the car to understeer but I have heard quite a few times that it will help the car power around corners without adding push to the car.
I can see how a Torsen on a stockish sprung car would cause a problem but we are talking about a car that isn't that softly sprung, comparatively. I would think this would already be a problem if it was going to be present with the Torsen since I don't see it "adding" or "realizing" more grip than what is currently there, just better managing it.
I could be wrong, we'll see when I get it, I just know that everyone I've talked to has said that a Torsen under power is far more neutral than a clutch based diff which always understeers under power or on entry if it is setup to be tight enough on coast and drive.
Well here's hoping that your get the job. So good luck with that.
I'd be curious to know what the people writing in to block the move to STU are saying. I'm mean what is their beef? That we'd be 2 fewer seconds off the pace of winning times?
Well if you do get the job, you can drive faster to Lincoln with 'professional courtesy'.
I think the cars are capable of a trophy at nationals in STX, but it'll take top notch driving and maybe the right course. We definitely don't gain enough speed on 285s to be more competitive in STU, but I am in favor of it- many street Mustangs ride on wheels more than 9" wide. If we don't go STU, I guess I'll stick to CP on street tires.
I guess I'm a bit jaded because of my experience, but I don't think either the new 5.0's or the 4.6's have a prayer in STX. Waaay too much going against the car in comparison to the rest of the class, even in the lightest of the light trim we are talking about 400+lbs to the nearest competitor in weight and the tire rules are the same for everyone. Combine that with torque of a V8 and you pretty much are left, pardon the pun, spinning your tires. J-Rho doesn't even think he can get it done within the framework of the rules and he is at 3100ish for weight.
There is an alternate solution to this and J-Rho certainly is going to be a major factor in it. In his "not official STAC" opinion, an STPony class would have a ton of success. Basically making it ESP on Street tires. I think that it has merit, but we are looking down the barrel of a gun with this. The BoD meeting is next month and that is when things get "rubber stamped" into the rule book. The chances of anything, anything at all making it to them this year is slim to none BUT, I suggest that if we want to have an ST class that we can be competitive in, we take J-Rho's thought process and put our weight behind maybe a provisional class for pony cars in ST.
Yup. STPony would be great. Rules: (not that the SCCA would ever go for this...)
1. Minimum 200TW DOT approved tires
2. Minimum weight 3200# (maybe? seems like an ok-ish target to be inclusive of lots of generations of pony cars)
3. No cutting or welding
I would be all for RWYB street appearing American RWD 200 TW excluding Corvettes&kit cars, even though my closeout tires are marked 140 TW.
We have a strong ESP class locally thie year, not sure if they'd give up the purple crack though.
Yep WDCR. Come say hi next time we're both there, ride along if you want. I run P classes right now because I have/can make the class letters easily, don't care about trophies, and want to run early to get home sooner. Next year maybe I'll get some STU letters- the car will be legal there if the BOD has ink for their stamp.
Justin
I can't wait to join you all up there in WDCR next season/year. Much better competition than BRR
Are you moving back to the area. We have the last event on the 6th come on up. ESP is going to be growing over the next couple of hears in dc due to the street class.
Decided to retorque suspension fasteners and play with the new GoPro Hero 3 Black Edition:
Front wheel camera is frightening on hard braking how much fore/aft movement there is. Terry was right!
