How would it have prevented it? Where can I go to learn more about this? I know slicks and hrd launches like to snap things, which things I would like to larn about to reinforce. "1pc alum DS and rear end" seem to be what people say...but I want to learn how and why.
Would this work with the Fays2 Watts Linkage?
I'm trying to build a AutoX and Strip beast.
When you mount stickies on a car, the traction gained with a high RPM launch caused the axle tube to flex forward. This puts stress on the differential and bearing caps.
To counter this, a rear girdle will protect the bearing caps from flexing and the axle tube brace will prevent the tubes from flexing forward causing stress on the differential and leading to breakage. Spider gears seem to take the brunt of it.
Hope that helps!
