skwerl
tree hugger
If it's a 3v then you shouldn't need a can on the passenger side. You can pull the line off and check for oil inside once in a while if you want, just the driver's side pulls oil.
Thanks again for the extra wiring harness and alternator bracket. Looks like I'll be able to reroute two of the four lines I have from the front of the motor to the back, should clean it up a bit.
