They won't be changing that 5th is 1:1 and there are four gears under it. That is the main problem with the MT-82.
But doesn't it depend on things like how wide your power band is? If there's a great deal of overlap between the gears within the power band, then I have to agree that the gearing is suboptimal. I haven't really noticed that out of my MT-82.
You are in no position to be condescending.
Not trying to be. I was rather under the impression that optimal gearing is at least partly a matter of opinion, similar to an optimal suspension setup. Perhaps it isn't, but at the very least, the gearing that works best is going to depend on the road course you're running if nothing else. For instance, it may be that on one road course, you wind up having to, with one gearing set, compromise between upshifting and hiting the rev limiter because the speed you're getting is just high enough to warrant upshifting, but there's not enough track to make it profitable, while with a different gearing set that issue isn't there at all; and yet, on a different road course, you find that same gearing to work really well because the speeds you're getting are such that it's "just right".
Wouldn't the "optimal" (which, here, means best compromise) gearing for a wide range of tracks, then, depend on those tracks? Seems to me you can't optimize for them all, so you have to arrive at a combination that works well for the most part, but isn't necessarily ideal for any of them. If the tracks they use as their benchmark differ substantially from the ones you frequent, wouldn't that result in a difference of opinion? That is the difference of opinion I speak of.
