AbdullaGT500
After putting in my new motor it has been extremely difficult to shift into gears. Along with the motor I replaced the slave cylinder with a new OEM one, and an exedy mach 600 clutch with an exedy steel flywheel. Still a stock tr3650 transmission.
With the engine off, it shifts into gear smooth as butter. When it is running at idle, it is difficult to shift into any gear at first, but once it is in gear it is easy to move through the other gears as long as you are still holding the clutch down. If you let off the clutch and push it again, it does the same thing over again. When driving it is the same way. 2nd gear is the most difficult gear to get into. Is it possible that I bent something on the shifter? Possibly a clutch issue?
