dieselboy28
sick my duck
So tonight as i was changing my valve covers i reached down and felt the timing chain and it had a little slop on the drivers side but the passenger side was just fine. is this normal?
T.I.A.
T.I.A.
And the drivers side the tensioner is on the top if I remember correctly.Top side or bottom side of the chain, if you are feeling the side opposite of the tensioner it will have less tension.
That would be correct.And the drivers side the tensioner is on the top if I remember correctly.
Ya the tensioner on the pass side is on the bottem and the drivers side is on the top.iirc the top of the passenger side was a little loose and the top of the drivers side was stiff. so this is normal?
