Not to stir the pot, just asking; since there seems to be a disagreement about what gears work the best on the A6 how does one find ground truth? There were people posting both for/against the 410's....same thing goes for the Boss IM, that seems to be another one of the arguments...
I look at it this way, the overall gear ratio is what is important. I even ran 4.30 gears for a long time and got into the 10s with them, but it was a total bitch to get the car hooked. Switched to 3.31 and lost nothing, but sure made the car easier to hook.
Consider these first gear ratios:
C4 - 2.46
4R70W - 2.84
6R80 - 4.17
Take the 4.17 and multiply it by the 3.31, you get 13.8 for an overall gear ratio in 1st. Now take that 13.8 and divide it by the first gear ratios of the other transmissions and this tells you what axle ratio would give you the equivalent with those transmissions:
C4 - 5.61
4R70W - 4.86
So, although 3.31 "sounds like" not much gear, you can see that in the end, it is quite a bit of gear with the 6R80.
We can do the same with the second gear ratios:
6R80 - 2.34
C4 - 1.46
4R70W - 1.55
That puts the 6R80/3.31 at 7.75, which is like a 4R70W with a 5.00 axle, or a C4 with a 5.31 axle.
And finally 3rd gear, where the 6R80 is 1.52*3.31=5.03, the others are 1 to 1, so 5.03 would be the equivalent axle there.
You'd all agree that an axle in the 5.00 range is a lot of gear, well, we're doing exactly the same thing with the 3.31/6R80, we just have 3 more gears to go after that.
Going the other way, a 4.10/6R80 in first gear is like having a C4 with a 6.95 gear, or a 4R70W with a 6.02 gear. You can see why hooking it is a problem.
