Somewhat a general question.
Current setup
4L Whipple
Whipple Monoblade TB
168# injectors
Fore triple return fuel
TR6 @ .028
When the car has sat for 2-6 hours after having been driven, she'll crank and fire up, revs to 1500 or so (typical for the tune) then dies. I can try it 5-6 times and same result. Only way to keep her running is to use the accelerator pedal to keep the revs up and after 20-30 seconds the car will find the idle.
If the car is stone cold or hot it finds the idle without issue.
I doubt its the tune as this did not happen for the first 6 months or so since the motor was done and the tune was checked and adjusted.
Thoughts as to what you think is the cause or solution.
Current setup
4L Whipple
168# injectors
TR6 @ .028
