TexasBlownV8
Formerly TexasBlownV6
What is to be used for the windshield washer squirters? Use the stock ones? Or is there some other style to use in the provided relocated mounting holes?
The back is solid, but rises above the cowling so when you have it bolted on and closed there is no seal between the hood and the cowling. It is completely open. You can see right into the engine compartment.
I'll take some pics later if you still want to see it.
How do you keep the torrential rain in Florida from entering the cowl when parked? Pictures please as I am seriously interested in a hood if I can save weight over stock but it is so hard to find any information.
Edit:
What are the weight savings on Steeda's Lightweight Radiator Support 05-10? Thanks!
The Steeda race cowl is definitely lighter than the stocker. Mine just came in(Thanks Gus!!), and it is way lighter. Pics coming.. Does anyone who has the race cowl hood NOT have hood pins? I am going to use lock tight on the hood latch bolts. I would think with the air not being trapped in their anymore, it wont build up as much pressure, hence, no need for hood pins..
Its funny you say that. I noticed a very small pin hole type deal on the hood, that wasnt there before. It was not from the highway or anything.
