Stock transmition rebuild kit.. and a stroker question.
Virgin_Mustang
Hi all,
I think my 3rd synchro is soon to die it goes khkhkht when I shift on high rpms ... so I thought I could save from now..
Is there a better transmtion rebuild kit for 2005 gt stock trnsmtion ?
and whats the bigged stroker kit I can find for the engine ? and whats thro pros and cons about them ? I heard over 302ci is just cooling problems. .
Thanks
05mustang_TT_charged
Because Race Car!!
LSU Country
302 is the biggest I would go with unless you but the new big bore block then you can bore and stroke it to 331 ci. with a stroker you will have more horsepower and torque because you have more displacement
chad05gt
Lake Charles, La
Transmission
http://www.thedrivenman.com/
931-646-4836 ask for Grey.
I live in Lake Charles, La. and in 2 weeks had my transmission with 36 spline shaft, heat treated gears,...etc. for $2300.:clap:
This guy is VERY personable and easy to reach.
My syncro prblems FINALLY solved.... WITHOUT needing tremec/bellhousing/driveshaft/shifter change.
Trust me... it'll be more than worth it to make the call.
btw,I found this place just browsing, looking for a tremec b/c I was too on my 3rd.
my 2c
Chad
Because Race Car!!
LSU Country
did he rebuild the TR3650 or did you swap to something else? Which shaft in the transmission is a 36 spline?
I am looking for a setup that can hold 650 rwtq and have 2 TR3650's. I am wondering if I can upgrade them or do I just need to swap to TR6060 or 4R70W
Virgin_Mustang
Like what kind of big bore blocks are we talking about in here ? who sells them?
Virgin_Mustang
Well what do u think of a T-56 swap ? something off a viper or the 2004 Cobra.. or what about the TR-6060 thats from the GT500 ? Which would fit better and still make my ride smooth with Gears like 4.30 or more..
Thanks
Because Race Car!!
LSU Country
Thanks
TR6060 is an easier swap, check out D&D Performance
Virgin_Mustang
I checked out the transmition there .. thats really not bad.. Do u think if I got high gears like 4.30 or more it would still be fine for a daily driver ?
and whats MMR site ? I can't seem to find it.
Thanks for the help. Apreciated.
