STOPTECH BIG BRAKE KITS-FREE SHIPPING!!
0% Financing Available for All Parts Purchases Through TPS!
**Ask for more details.
ALL STOPTECH BRAKES PURCHASED FROM TPS HAVE THE LATEST FORGED CALIPERS SIMILAR TO THE TROPHY SERIES
Are you looking for the ultimate in braking for your Mustang? TPS has the solution for you with Stoptech's Big Brake Packages! Choose from 1 or 2 piece 13", 14" or 15" Rotors and 4 or 6 piston calipers! This setup will eliminate just about any type of brake fade you may have. These sets are available in Red, Blue, Black, Silver, or yellow. Includes everything (lines, pads, calipers, rotors) to bolt up to your 1979-2012 Mustang!
StopTech 2-piece calipers have the lowest amount of flex and deflection among 25 of the leading caliper models (including some monoblocks) from well-known manufacturers. This is accomplished using StopTech's patented bolt-in bridge, which is strong enough to stop distortion without sacrificing cooling through the top of the caliper.
Stiffer Calipers Offer:
-Less vibration
-less Noise
-Better pedal feel under extreme braking conditions
-Faster braking response
-Less pad taper
AeroHats that offer up to 80% greater airflow
StopTech has developed several design innovations to improve rotor airflow. The patented 2-piece AeroRotors push more air thanks to curved, airfoil-shaped vanes and an air channel that widens at the trailing edge of the vanes. StopTech aluminum AeroHats are lighter, and feature directional stand-offs between the rotor and mounting hat that increase airflow to the (hotter) outside face of the rotor by over 15%.
Benefits of StopTech® AeroRotors® and AeroHats:
*Specifically engineered and patented AeroVanes for optimum cooling
*Optimized to provide even performance and consistent feedback
*Longer pad and rotor life
2005-2012 Mustang
*14"-15" 2PC Rotors, 4 & 6 Piston Calipers
1994-2004 Mustang
*13"-14" 2PC Rotors, 4 Piston Calipers
Mustang V8 (Fox Body) w/ SN95 Front Spindles
If you are interested in a set please contact me via PM or at 408/898-4632
-Less vibration
-less Noise
-Less pad taper
2005-2012 Mustang
1994-2004 Mustang
