Suspension Install - Shop Recommendation
Bocefus
Looking for a good shop in Northern VA. I am ready to have a few suspension parts installed and am looking for a shop with a good reputation. I know a lot of you have had work done and would appreciate any insight you can provide.
The place I was planning on going to recently closed their doors.
Parts ready for install:
BMR: Springs, LCA, Relocation Brackets, UCA, UCA Mount, PHB
Koni STR.T struts/dampers and GT500 upper strut mounts
1 inch Spacers
Any information is appreciated.
Thanks
Mid-Atlantic Performance
JPC
moved to regional
BMR Tech
Traction Vendor
Tampa, FL
Mid-Atlantic Installs a good amount of BMR Suspension pieces, and I have not heard anything negative about them.
1730 Arlington Rd.
Richmond, VA 23230
804-332-6685
mfergel
Richmond, VA
MAP - If you can get in touch with Mike and if you aren't in a hurry to get your car back. They did install my upper and lower control arms and Roush springs (as well as my rear end gears). I had to have the rear end re-done. Clunking in the rear end as well (but I really think that's a problem with the J&M upper arm). Can also look into Performance Autosport her in Richmond. Bit pricey though.
I don't really consider either of these to be 'Northern Virginia' though.
Bocefus
Where about in Northern VA?
Loudoun county
1730 Arlington Rd.
Richmond, VA 23230
804-332-6685
Thanks Kelly
Not hard to do if you have any mechanical ability.
Embarrassing to admit but mechanical ability stops at checking oil and pumping gas lol
Richmond is a bit far but it's an option based on the good things I keep hearing about them.
bullitt0175
bullitthead
For what it's worth I'm about an hour from you and I have a shop.. I could do it for you
Besides my original offer, there's a shop in manassas called excessive Motorsports that's all mustangs.. Bring your check book!
If it were me I'd make the drive to MD and get it done by woodbine Motorsports or jpc..
