justinS197
Go low or go home!!!
I sold my s197 a while back and started a fox project. It a 89 coupe with a 408w stroker. Its been a "2 years of time,money and learning" project so i guess this is my unofficial, official build thread
S197 that wil forever be missed
The Basics
Engine:
Forged bottom end
h-beams
dished pistons
Afr 205s
Comp Cams 608 lift 248/258 split dur. and 114 lobe separation
Transmission:
TKO 600
Suspension:
Front Coilovers
Tubular K member
Tubular A arms
Brakes:
Wilwood 6 pistons in the front
wilwood 4 piston (rear)
Rear end:
SN95 rear axle
Eaton Detroit Locker
3.73 gears
Painless wiring harness,new msd way more stuff then listed.
The car i started with......... not much but i payed 1900 for it
Had a little fun with the car with the stock 5.0 for a while.
So we pull the 5.0 out take off the intake and this is what we found.... oiled up shop rags
I drove this car from Cartersville Ga all the way to Douglasville, then numerous times from douglas to Fulton or Barrett Pkwy, luckily it didnt break down!
Had to get a new front core support welded on , new subframe connectors, new floor pans , a cage and the scott rod fab engine bay panels welded up
Stripped it all down and had it painted Blue Flame Metallic like the ford Raptors and f150s , body work came out great..
The Basics
Engine:
Forged bottom end
h-beams
dished pistons
Afr 205s
Transmission:
TKO 600
Suspension:
Front Coilovers
Tubular K member
Tubular A arms
Brakes:
Rear end:
SN95 rear axle
3.73 gears
