My weapon of choice will be a Novi 2200
Forged Cobra crank (a stock Ford piece), H-beam connecting rods, a quality 2618 forged piston, stainless steel rings, ARP main & head studs. Add boost and fuel. We've done stock block/crank/head/cams/intake four valve modmotors that went to 1400 with single turbos. Twins are even easier. Three valve heads are damn good and it wouldn't take much more than that to reach 1000 hp easily. As others have mentioned, an experienced engine builder can point you in the right direction.what would it take to run 20+ psi?? I want to know if the 4.6 3v can live at supra boost levels. The supra can inhale massive amounts of air, and they make insane power. A 3.0 liter making 1000hp is very impressive, and now they are stroking them to 3.4 liters, and making 1200rwhp +! what does it take to build a 4.6 3 v to take 30psi?? And what numbers would it make?? The world may never know.
Whoo whoo, I get to try out turbo. This is probably your evil plan to get me to want to buy a turbo off you guys and have you install it.
Come up here and drive mine. I'll bet it does not kick ass any beter than yours does!
Bill said that!!
I have an 07 gt with 3.55 and manual trans....i'm looking to make somewhere around 450rwhp on an otherwise stock motor for a couple years untill i can afford to build it and jump up the power.....with all of that said it's my second car and i never take it to the track i just run around the streets with some friends that are all around the same power levels in their 350z's, supras, and wrx's so i'm looking to be able to run around with them and not left behind all the time....that is untill i get to my ultimate goal of around 700rwhp.....so anyone with personal experience with any of these setups or anyone who knows more about it then i do i would appreciate some imput on the following kits
i'm looking to stay around 4000 for the kit if i have to go up to 5500 i will but only if it makes that huge of a difference oh and i live in dutchess county NY so i do have to worry about emissions but as long as i can get the computer to say everything is right i have a way to pass the rest of the inspection ie no mufflers cats etc.
I'm looking at the hpperformance stage 1 single turbo kit http://www.hpperformance.com/2005mustangturbosystems.htm
but they don't tell you any of the details or specs of the system
or the twin hpperformance kit which i could only find on the turbochargedpower.com http://www.turbochargedpower.com/05-09 Mustang Twin.htm
the third option is the single turbo kit http://www.turbohorsepower.com/kits.html
i tried to look at the powerhouse setup but it appears that the site is down so i can't find out any information about that
Nothing hard about the install on my twin turbo system. Complete bolt on.turbos better but i'm going to go with a supercharger for ease of install
.Nothing hard about the install on my twin turbo system. Complete bolt on.
..but it ain't cheap! Probably worth my entire car. Lol. But seriously, that is my favorite setup. And before u or someone else says it.. yeah there are other "easy" kits out there.
I've seen turbonetics kits on ebay under 5k, but don't run into many peope running them comared to the other choices out there. Are the rumors true that they are difficult to tune? Or is that just the general perception applied to all turbo setups?
And, as a side note, fuck a Supra.
I'm your Huckleberry.
