May 6, 2023 #1 Hollowdweller Member Joined Jul 10, 2018 Posts 324 Reaction score 37 Got it installed correctly…I think. Wanted to get a check. Found an old pool fitting to help with the job lol. Does the seal sit flush or recessed? Should I knock it down more? Repainted cover.
May 6, 2023 #2 whitmanink Member Joined Dec 28, 2020 Posts 207 Reaction score 43 Location denver pa looks just like mine did when i replaced mine,, no leaks , looks flush and seated even,,,, send it
May 9, 2023 #3 brasil Member Joined Sep 14, 2019 Posts 60 Reaction score 10 Location Duesseldorf Germany looks good. Don´t forget to use a little grease when you install the balancer .
May 9, 2023 #4 J JC SSP Senior Member Joined Nov 8, 2022 Posts 1,084 Reaction score 469 Location FL Don’t you put a dab of RTV seal at on crank woodruff key?
