Beerhunter
I have searched everywhere and I cannot find much information on replacing ball joints. The only information I can find is that the control arm needs to be replaced with the ball joint. I have also read that you don't need to do this I heard you can simply press out the old ball joint while it is still on the car. This is the route that I am hoping to go. I have the ball joints and I have a ball joint press. My question is, what parts do I have to remove to before I start clamping down with the press? and b) should I be trying to press it out from the top or from the bottom.
I have never done this before but I have wrenched a lot of things in the past. Any tips or directions would help greatly. I'm trying to do with removing as little parts as possible.
Thank you
Thank you
