CammedS197
Thanks fast Ed!
Our two piece driveshafts are good at high speeds right? Just want to make sure lol!
Seems to be. Mine repeatedly sees upward of 6000 rpm - down the faster straights my 5900 upshift indicator is blinking and I'm in 4th gear (1.00:1). That's about 125 mph on tires that are listed at 25.9" tall, or about where you'd be with 3.73 axle gears and 27" tall tires.Our two piece driveshafts are good at high speeds right? Just want to make sure lol!
I can see how it was decommissioned, given it's primary constituents were puppy tears, unicorn blood, and viable presidential candidates.I'm surprised you could still source the blue brake fluid, as it was recalled a couple of years ago specifically because of its color. And I think Florida had been aware of the matter further back than that.
Norm
Nitto NT01 is a full race compound. It cannot be driven on the street, even just to an autocross and back.
No it's not...A 100 TW tire is not a full race compound. You could street drive all day on that tire if you wanted.
http://www.discounttiredirect.com/d...byName.do?tmn=NT-01&typ=Passenger/Performance
Yeah, go do that for a couple hundred miles and then report back.No it's not...A 100 TW tire is not a full race compound. You could street drive all day on that tire if you wanted.
For all intents and purposes, that is a race tire.
Sent from my Samsung Galaxy Note 4 using Tapatalk
The 01 or the 05? Because I've seen what happens when you put about 100 highway miles on an 01, and the tire looks like it went through a shredder. I've never heard of anyone using an 01 as a street tire.In what way? Not trying to argue. Are you saying they would wear out too fast, be too noisy, wander on the road, what is it? I know plenty of people that drive around on the NT01 for a lot more than just to and from the track and they love it.
Back in the day I put like 3000 street miles and countless track days and autocrosses on RA1s and they sucked the same as they did when new.
You know the Camaro SS is what started that whole "factory R-compound" thing, right?
Street driving WILL heat up R-comps enough to heat cycle them. They are softer and stickier, after all.Obviously there is some idea here that street driven tires under normal driving actually heat up enough to heat cycle. Yeah, I'd need to see some real world data to believe that. As it is I'll may have to do some testing of that myself.
Sent from iPhone
180*F, according to Tire Rack.Someone explain what is considered as an actual "heat cycle" 30, 40, 60, 100 degrees above ambient?
Personally I don't think 30-40 degrees above ambient can be considered a heat cycle, if so then most people's race tires are heat cycling while sitting in a rack inside their enclosed trailer or inside their race shop.
Sent from iPhone
