Torque Arm vs 3rd Link
There are several good observations and also some misconceptions in this thread that can probably be cleared up pretty easily.
Why is a properly designed torque arm (TA) better than the OEM 3rd link for an S197 Mustang?
The simple answer is that the TA improves chassis stability by moving the load inputs from the rear axle in both acceleration and braking closer to the center of gravity. This creates a more connected driving experience for the driver that generally leads to improvements in lap times since the driver can more easily sense what the car requires to do what the driver asks of it.
The S197 OEM 3rd link is superior to any suspension system that Ford or GM ever used on their live axle pony cars. This is especially true for the 2011-2014 models since Ford updated the geometry by lengthening the UCA. As such, all statement below will be relative to the S197 OEM suspension.
Why would we want a significant amount of antisquat in a pony car? Weight Transfer to the rear tires is why! We want to load the rear tires as quickly as possible since early power down is king when it comes to reducing lap times. Pony cars generally have significantly more front weight than rear; 52-57% front weight bias is pretty standard. When you see a car squat down a lot in the rear under throttle it is not necessarily a good thing because the entire load has not transferred completely until the car has fully squatted and takes a set. Full torque is already acting on the tires and it can easily blow them off before the vertical load arrives. What if we could transfer the load almost instantaneously instead of waiting for it to arrive? That is what antisquat (AS) does. It allows the load to bypass the spring and shocks and feed directly into the tires through the other suspension components.
Why not just go for as much antisquat as possible? Since AS locks out the springs and shocks it can cause problems. If the road surface is bumpy we want the springs and shocks as active as possible to keep the tires in contact with the road and loaded as highly as possible. Lot's of AS will not allow this to happen because it can cause the vehicle to loose traction in these conditions. This is the brake hop that people are mentioning. The specific design details of a particular platform (FOX, SN95, F-body, S197, etc) will determine how much AS can be tolerated in a given situation. The shorter wheelbase chassis (FOX, SN95, F-body) are more sensitive because a shorter wheelbase means that the total weight transfer will be higher. An S197 has a longer wheelbase and will inherently be more stable and tolerant. There are other factors at play and a couple of the most critical are the braking bias and ABS programming. Again, the S197 is far superior to the other cars with the newest S197s being the best. Not surprisingly, how the driver downshifts the car and applies the brakes needs to be a major focal point in any brake hop discussion. Drivers with sloppy footwork and poor rev-matching will have the biggest problems with a car set up with a lot of AS.
Notice that up to now we have only discussed AS without pointing any fingers at TAs or the S197 3rd link. The reason is that both the TA and the 3rd link can be set up with a wide range of AS amounts. The AS adjustment with the CorteX TA is done with the lower control arm (LCA) drop brackets on the axle. The ride height of the car also changes it a little. With the 3rd link, AS adjustment it is also done with aftermarket LCA brackets and can also be changed with an adjustable UCA mounting brackets that also allow the angle of the UCA to be adjusted. There isn’t much adjustment range in the UCA bracket because space is limited. The AS can change wildly with the 3rd link arrangement because the UCA is short and its angle changes a lot with the car lowered. This brings me to my next crucial point.
1. The CorteX torque arm, when used with adjustable axle bracket, is relatively insensitive to ride height changes. Lowering the car a lot will not cause the rear suspension geometry to go down the toilet. The S197 3rd link design was driven by packaging constraints so it has a really short UCA. When the car is lowered to track height the geometry becomes highly compromised with too much angle in the UCA leading to serious geometry instabilities. Aftermarket UCAs cannot raise the chassis pickup point high enough to fix the problem. Compromises are required.
2. Roll steer is rotation of the rear axle relative to the chassis during body roll from cornering. Roll Understeer is when the rear axle turns in the same direction as front tires going through a corner. Roll Oversteer is the when it turns opposite the front tires. We need the rear axle to roll understeer so the tires can generate some slip angle, which creates lateral grip. When we add significant AS with a 3rd link we end up with undesirable roll oversteer. If we pull out the AS then the car has trouble with off corner power down. The torque arm can be set up with more AS, better rollsteer, and a lower CG, all of which will reduce lap times. With the short OEM UCA and sensitivity of the suspension to ride height you can imagine the problems that might occur when hitting bumps with the car mid-corner. The amount of rollsteer rapidly changing with every bump causing a condition at the rear very similar to if the driver were sawing at the wheel but now on the rear axle. It’s most subtle than that but clearly this phenomenon does not help with chassis control or stability.
3. The less power, more rear weight bias, and tall ride height a car has the least benefit the from adding a torque arm. Lowered GT500 stand to benefit the most. A 2005-2010 V6 mustang will benefit the least.
4. The CorteX TA moves the pitch center of the vehicle under braking closer to the CG reducing noise dive. Combine that with increased AS you end up with a car that work amazingly well with lighter springs. Running a racecar with as soft of springs as possible is critical because it saves the tires allowing it to perform better than cars set up stiffly during a race or longer open track event. This is a double benefit for streetcars because it makes them more comfortable to drive around town. Win-Win. Anyone trying to sell you coilovers with front spring rates above 600 lb/in for S197 or S550 clearly does not understand mustang suspension setup. The car will have less mechanical grip and will go away quickly. The car might feel like it handles better at first because it will respond very quickly to steering input and might get heat in the tires faster but those perceived benefits will quickly deteriorate if performance is actually monitored.
5. For trackday guys and racers it is important to know that if conditions are smooth you can run more AS successfully. If you are on a rough and bumpy track then it is better to back off the AS and focus more on shock and spring adjustments to optimize power down.
6. The torque arm weights about 20 lb however the 3rd link and bracket that are removed during the installation are about 10 lb. So yes, a TA will add a small amount of weight however it a very small percentage considering the rear axle housing is 250 lb+ of unsprung weight. Ground clearance is not compromised because the TA is completely tucked up above the S197 exhaust system and really only reduces ground clearance directly below the differential. That means that going over speed bumps and angled driveways will not cause any problems. If you find yourself needing to straddle something in the road like a big rock or driving with one side of the car on the curb then you might have problem however those are not typical situations in a performance mustang since they were only 4x4s off the showroom floor
