MechE
Great discussion gents. Thank you.
Filip,
Welcome, and thank you for bringing the tech to light on this subject. Both pros and cons...
Hope you stick around; a number of us would value your insights.
Norm, of all your arguments this is the most disingenuous one. You are an engineer and you know if brake hop is going to be an issue at all it's completely dependent upon the geometry of the vehicle and the torque arm relative to it.You'd never call it hyperbole if you had seat time in certain years of the 4th gen F-body.
Keep in mind that the parts and the suspension configuration don't know what emblem the car wears and doesn't care. You should care about the F-body characteristics, because with slight differences in detail or maybe just bushing/rod end wear maybe it could be your car with the dancing stick axle in the braking zone. Not all 3-link cars hop under acceleration, either. The devil is in the details, not the badge on the car.
FWIW, I've driven F-body cars in autocross competition, and they're easy cars to drive hard as long as you stay out of brake hop.
Translation - I'm not anti-torque arm. And FWIW I've probably watched all of Filip's videos at least once.
It's easy enough to find examples of F-body brake hop in case you'd rather not take anybody's word for it. The interesting part starts about 30 seconds in. Me, I'd prefer that the fillings stayed in my teeth
http://www.bing.com/videos/search?q...27CBF27FCE8BB36C53FB27CBF27FCE8BB36&FORM=VIRE
Norm
Watch the video again. He Explains why the torque arm more effectively transfers torque to the tire rather than dissipating it through the chassisI, too, have watched the video, and understand the terms involved. He describes why a torque arm is useful (yields good anti-squat when the lower control arms are configured properly). But importantly, he doesn't explain how it is superior to the upper control arm the Mustangs come with. He doesn't even hint at how it is superior in that respect. He shows how you can get certain amounts of anti-squat with different lower control arm angles in conjunction with the torque arm. He doesn't claim that you can't do the same thing in the same way with an upper control arm setup.
Now, that doesn't mean that the torque arm he designed isn't better in at least some ways for at least some things (it could well be, and he appears to be enough of an engineer that I find it unlikely that he'd settle on that solution without good engineering reasons). It only means the video doesn't explain how it might be better, and that means the video you referred us to doesn't tell us what you claim it does (which is to say, it doesn't tell us why you'd want a torque arm instead of the upper control arm).
I'll second that!
I think it's interesting that the problems with the 3-link's SVIC come into play when the car is lowered to race height. But that raises the question: why lower the rear in that manner? We're talking about racing, in which appearance is irrelevant. So what if the rear makes the car look like a 4x4? If the geometry is good back there, who cares?
If you lower the rear by, say, 1.5 to 2 inches, what are you really gaining, assuming that your geometry and spring rates were optimal prior to the drop? Sure, you lower the CG slightly, but (from what I've seen) you also move the rear suspension's roll center by about the same amount, so the roll arm's length remains the same.
Running softer springs (which, as Filip notes, is desirable, but obviously that doesn't imply that the stock rates are anywhere close to optimal!) necessarily means you have to have more available travel, but that means less lowering than you might otherwise perform. I expect you'd want to keep the suspension off the bump stops because the bump stops represent a rapid and large increase in the stiffness, and dampers generally don't have position-dependent valving -- which means the dampers will be asked to damp what amounts to a much higher spring rate for however long the suspension remains in the bump stops. This is a similar problem to running progressive springs, only much worse.
All of which is to say that this looks like a big, messy compromise, and I'm having some trouble understanding why it seems there is such a strong desire to lower the cars substantially (particularly up front, where lowering the car increases the roll arm at twice the rate the car is lowered. And note that "substantially" here means "enough to noticeably affect the geometry"). That is something I'd very much like to hear Filip talk about.
Filip,
Filip,
If maintaining stock ride height is desirable to you then the torque arm is your friend. With a torque arm you don't need low stiff Springs to keep your car level.
Sure. I'm not arguing that there are no advantages to be had by lowering the car. But if you're really going balls to the wall, then you'll rip out the entire front suspension and replace it with a SLA suspension, just to get rid of the camber related compromises that come with a McPherson strut suspension. Done right, you'll even be able to locate the roll center exactly where you want it.As for suspension geometry that can be corrected. I use the Maximum Motorsports K member which allows me two mounting holes for my lower control arm to correct for changes in suspension geometry. Also lowering the car up front is absolutely necessary for her aerodynamics. This car's high drag coefficient, needs to be ameliorated somehow.
Where is the video where it shows why you want to have a torque arm? Sat though the entire 13 minutes still don't know why you would want one over a three link.
But Filip himself just now said that the torque arm gives you the least amount of advantage with a car that has a stock ride height, relative to one that is lowered.
That's not to say that the TA won't bring any advantages to a stock ride height car. On that, I cannot say. I'd like Filip to chime in on what those advantages would be if you keep the rear suspension the same as stock as far as geometry goes.
But here, we're talking about the rear suspension, and why you'd want to lower it. I suppose there might be some additional drag reduction in lowering the rear, but oddly enough, the first thing that'll be done after that is to add aero to the rear of the car which increases drag. I've no idea how much rear downforce you'd lose by lowering the rear of the car by a couple of inches. Having the front lower than the rear means the floor of the car is canted slightly, which will yield a low pressure area under the car, which in itself causes downforce. You'd lose some of that effect by lowering the rear.
KC , that is true which is why I deleted the comment. However all advantages are relative. When I first put the torque arm Watts link and control arms on my vehicle I was running the Boss 302 Springs. They were tall and soft. The torque arm was my friend not necessarily because my Springs were tall but because they were soft. So I was really referring to my own personal experience and it was incorrect with respect to the "tall" part. That being said if you want your stock ride height vehicle to drive a whole lot better put that cortex Watts link and torque arm on and it it'll be a different car. And you will notice its advantages much more then if you had coilovers already on cuz you will notice the difference in anti Squat and anti dive more on the stock SpringsBut Filip himself just now said that the torque arm gives you the least amount of advantage with a car that has a stock ride height, relative to one that is lowered.
To be clear, I'm not disputing that there are advantages to lowering the car in the rear. I'm asking what those advantages are, especially in light of the geometry compromises that inevitably result.
My understanding of vehicle aerodynamics is that aerodynamics are the best with the front lowered at a rake. So from that perspective you would want a little bit more ride height in the rear than in the front. But if the rear is too high relative to the front then you obviously have center of gravity issues and problems with geometry on cornering etc. If you read Filip' s explanation, The torque arm is more effective with a lowered vehicle.
Dude seriously if you don't have any tech don't even acknowledge me as existing. You obviously have a vested interest in pushing Cortex shit. Give me a reason to run a TA over a (key words here) spherical bearing three link with proper geometry. Of course adding a torque arm, Watts and relo brackets, on top of dampers, springs and bars to a stock mustang will make the car work better. No one is debating that. Because from every video I see from those guys, that's what I see, their parts (which are quality pieces) added to a stock car. Let's see them take a sorted car such as Vorshlag's old car or Marks old car or even mine and show me how much faster it would be with a torque arm.
My Fox hopped like a motherfucker with a torque arm. Ended up putting autozone pads on the rear to basically take the braking out of it. If the S197 didn't have ABS or would too.
Dude Lol, you're all over the place. Lowering the car in both the front and the rear improve your center of gravity and even a one-inch drop makes a big difference in handling provided you correct the geometry which is easy enough to do. You keep talking about it like it's this big mess? It's not.Right. That's my point. You lower the CG of the rear some, but it is minimal, and you now introduce geometry changes in the rear that you have to fix.
If lowering the rear simultaneously reduces the downforce (by reducing/eliminating the rake) and introduces geometry problems that you then have to correct, it raises the question of exactly how much benefit you'll wind up with in the end when you've done all that, compared with what you had before you did all that. Are you really going through all that effort for what amounts to a couple of inches (less than 10%) of CG drop, zero roll stiffness increase, and a reduction in downforce? That's something you'd want to do if you're competing, of course (you'd be using a wing in the rear to gain your downforce back), but then, if you're competing, you'd want that SLA suspension as well, no?
And that raises another question about the TA: how does it affect one's ability to throttle-steer the car?
Sounds Guy Dave, thank you for thanking Filip. 1) Are you prepared to moderate your views with respect to torque arms on the s197 chassis? 2) are you prepared to stop mocking me for advocating it? 3) Are you prepared to thank me for bringing this issue to the fore so that you could have the opportunity to have direct discussion with Filip himself?. ;-)
Since Filip is the chief engineer for racing teams that run at the highest level of racing that the s197 competes in I think he could do just that. I am sure that he could take any car that anybody on this forum runs and make it faster with his torque arm. And he explains why. With a torque arm you can run softer Springs and maintain better grip. There are people on here including Terry Fair that are running 800 pound Springs. Filip just explained why there is no performance advantage from Running Springs over 600 pounds.
1) I will moderate my views when I have been sufficiently convinced that there is sufficient benefit compared to a properly set up 3-link (all rod-end, maximized adjustment on the UCA).
2) No. Bring tech beyond "it's a supercharger for your suspension" and I'll stop.
3) No. I still feel that you are pushing forward an agenda that goes beyond simple presentation of knowlege and experience. I think that you pulled Filip into this mess only to support your agenda, not because you think he would be a fantastic resource to the S197 community. That he could be that fantastic resource, I have no doubt.
Too many times you've come across with the attitude that if you don't have it on your car, it's worthless, and if somebody doesn't have something you do, they're idiots. With no hard facts to back it up. When pressed for something that isn't purely subjective, like lap times, data acquisition streams, or the like, you backpedal into ad hominem attacks or straw man arguments, and that's just not something that works around here.
I welcome Filip with open arms. I have buddies that I race with that use his products, and the build quality is excellent.
I just think the jury is still out on the TA situation pending further discussion of some of the fine points. The devil truly is in the details.
So . . . you're not an engineer and you're trying to tell me what is and what is not involved in an engineering problem?Norm, of all your arguments this is the most disingenuous one. You are an engineer and you know if brake hop is going to be an issue at all it's completely dependent upon the geometry of the vehicle and the torque arm relative to it.
Big hint from suspension 101 . . . everything affects everything else.
Norm
No. It's to put the entire thing into context. In the absence of a budget, when the fastest lap times are what one is after, then it follows that one will spend money on the SLA suspension to replace the strut-based suspension because doing so gets you much better control over the camber curve and, simultaneously, allows you to set the roll center to something better suited to racing (that latter assumes that the design is done with racing in mind, but that's a pretty reasonable assumption).And of course An SLA front would be better, what does that have to do with anything? Is that an argument for not lowering the front of your car?
That's good to know. I have the Boss 302 springs (standard up front, Laguna Seca in the rear) and the 26mm sway bar, and it really made the rear come alive as well as substantially improving the turn-in, enough so that I don't notice a response delay in the suspension anymore.As for throttle steering, I'm not a good enough driver to do a whole lot of throttle steering and I dare people to throttle steer around the track I go to such as Willow Springs. I have seen people do it but I'm not throttle steering at 130 miles an hour around turn 8 and turn 9. However I am a good enough driver to do donuts and 2 break my back and loose for fun and the torque arm gives you excellent control over your back end. Between my torque arm and my Torsen t2r my car's a drifting machine if I want it to be. In fact I put a real stiff 26 millimeters sway bar on there and did just that.
