barbaro
- Joined
- Jan 23, 2011
- Posts
- 281
- Reaction score
- 0
Right. But now that we've seen that, we can all make points well! Win-win in the end.
Interesting. I have to wonder what that does to the balance. With the adjustable Watts Link, however, you can control the rear roll center of the vehicle, and maybe that's enough to get the car back into balance, at least with respect to neutral throttle.
Yeah, that's exactly the experience I've had as well (see, subjective impression is valuable!).
Even just going from the 24mm rear bar that came stock with the car to the 26mm Laguna Seca rear bar has made a major difference in terms of the turn-in responsiveness of the car. It went from the turn-in delay (which is really the amount of time it took the car to take a set -- the actual direction change delay of the car seemed to be much shorter than the time it took the car to take a set, which was odd) of maybe a couple of hundred milliseconds to something low enough that I can't detect it.
Oh. You no longer have that in the rear anymore? Given what you say below, I guess that makes sense.
Yes, I agree, the car is easy to drift now. But that makes it a lot of fun, even if it isn't as fast.
It sounds like he might be a fan of trail braking into the corners (that will definitely keep the front loaded on corner entry!).
That's quite interesting. Did you ever have your 26mm bar on the car with the other pieces (torque arm and watts link)? If so, what were your impressions of it before you went back to a smaller bar?
OK, thanks. I'm at 191 lb/in in the rear right now, which is so close to 200 as to make no major difference. But my front is at 148 lb/in, which is a lot less.
Right. The nice thing, though, is that Filip is an engineer. He solves problems. If you want the car to have certain handling characteristics, he'll be able to come up with something that gives you that, as long as what you're after is within the reasonable realm of possibility.
So you're running 400 lb/in up front with JRI dampers, right? Previously, you were running 148 lb/in up front with the Koni Yellow dampers -- exactly what I'm running now. What's your impression of how the front end works over bumps and the like, especially in comparison with your previous setup? And are you able to adjust the height of the front to match what you previously had with the Boss springs and Koni dampers? I simply cannot lower the car up front any more than I have, because I wouldn't be able to get my car onto my driveway otherwise. But if the CorteX JRI coilovers can be adjusted that high, then they would be a possible upgrade path if I end up deciding I need more rate up front for whatever reason.
I have had several different Spring packages on the car searching for that perfect ride. with the Jri's at their highest ride height setting they are about an inch below stock. I get almost stock ride height by running 27.7 inch tall 275 40-19 tires in the front and 28 inch tall 285 40-19 tires in the back.
Now this is one of the other compromises that I've made. Handing purposes a 35 series Tire is of course much better. However, my car is a street vehicle on the worst streets of any metropolitan area in the United States according to the National Traffic Safety Association. And also according to me. I can't emphasize to you enough how horrible the pavement quality is around where I live and the potholes. I have blown out shocks ball joints and rims on the roads around my home. The taller tires are an absolute necessity not just for ride comfort but to preserve the equipment.
They do contribute to plusher ride quality though at the trade off of some vagueness in the steering wheel. Steering is still very direct but you don't feel the road as much.
