TPS 14" 4 Piston Brembo GT500 Big
Brake System-$999 FREE SHIPPING!
Click here to order
http://www.tpsmotorsports.com/tps-14-4-piston-brembo-gt500-big-brake-system-2005-2012-mustang.html
Are you looking for a GREAT Brake upgrade for your 2005-2012 Mustang? TPS has put together a great package that will give you ALL the braking power AND MORE of the GT500!
Upgrade your S197's front brakes with the massive TPS 4-piston Brembo kit and get the confidence you need to dive into the corners at ultra high speeds. Brembo makes braking systems used by the top race teams and manufacturers in the world, including Ford Racing.
This bolt-on upgrade kit includes GT500 4-piston calipers, street pads, your choice of zinc coated rotors (slotted, cross drilled/ slotted, slotted/ dimpled), and braided DOT-approved stainless steel brake lines (optional).
This great brake upgrade kit is designed for all ABS-equipped 2005+ Mustangs, including the V6, GT, Bullitt, and GT500. Will not fit non-ABS equipped Mustangs. Requires 18" or larger rims for proper clearance.
Click here to order
