blahdo_s197gt
Hey everyone I just picked up a 2011 Mustang GT Brembo Package. The vehicle has 40,000 miles on it and i'm looking to do a full tune up on it. I do have a few questions which I highlighted in red, is there anything else i'm missing that I should do at 40,000 miles? Thanks a lot everyone I appreciate all the feedback and help!
So far I have the following;
PS - I know the brakes need to be replaced as they're heat spots on the rotors and the brakes just don't bite like brembo's should.
StopTech Drilled & Slotted Rotors Front & Rear
Hawk Track Pads Front & Rear
Amsoil 75w-140 Gear oil
Amsoil 5w-20 100% Full Synthetic Oil (Should I go with the 5w-50? The oil cap says 5w-20 but I know the 2013-2014 track packages take 5w-50, why is that?)
Amsoil Oil Filter
Ford Motorcraft Transmission Fluid (Is there an amsoil alternative, or should I stick with the OEM crap?)
Ford Motorcraft Coolant - I'm draining the coolant completely and doing a flush.
NGK IRIDIUM IX PERFORMANCE SPARK PLUGS - HEAT RANGE 7 (What should the spark plug gap be on a stock Mustang GT that will eventually have an intake/flash and cat delete. Are these plugs recommended or should I stick with the OEM Pre-Gapped Plugs?)
Amsoil Oil Filter
