Valve spring question
KonaGT
Does anyone know if the O.D. of the intake springs is the same as the exhaust?
Does anyone know the factory installed height and spring rate on the stock springs?
Coyotetivct
The intake and the exhaust are the same OD. The stock springs are 50-70lbs at the seat. It is not a lot of pressure.
beefcake
Forced Induction Specialist
Bethel, Ohio
i'm running the livernois, shimmed a bit
Specifications:
Install Height: 1.575
Max. Valve Spring Lift: .580
Spring Pressure Closed: 70lbs
Spring Pressure Open: 190
Coil Bind: .950
KonaGT
It would be a inexpensive upgrade to swap over to the Boss springs. I wonder if anyone is doing that with stock cams.
beefcake
Bethel, Ohio
Not stock cams but switching to Boss springs and valves with my Comp Cams Stage 3 cams.
the boss springs are not much over stock. if your going to take the time to swap, i'd go with the livernois
audidog
Frisco, Tx
Very true I was shocked to see how little difference there was between the two when I was looking at my options.
KonaGT
I want to leave the stock cams in my car is the thing, so I don't really need a bunch of extra spring pressure. I'm just thinking maybe the Boss springs might be better for a little more RPM and possibly a little better valvetrain stability. I won't need them for more aggressive lobe profiles.
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
Why would you up the spring pressure with stock cams? How would that affect "valvetrain stability" or let you raise the rev limit? All it would do is slightly increase valvetrain power loss (due to the increase in needed force to open the valves) and perhaps cause unwanted spring harmonics. The stock valve springs were specifically engineered for the stock cams.
Sent from my DROID2 Global using tapa-whatzit-thing
Kingcrabb
Cecil County, MD
Valve Float?
A stronger spring will reduce floating valves allowing him to rev higher safer and still make power...
Thats all i could come up with. But still, if you're going to take the time and money to do it you may as well go with the best spring out there.
KonaGT
Stock vlave springs may not have been designed to go much more than the stock rev limiter either?
And perhaps they may have more harmoics, and perhaps they may have less. You should do a spintron test and let us know.
