GrabberBlue5.0
Gold Member
Top notch customer service there!
Absolutely. Even after I told him I would call myself, he still insists on helping me get this taken care of. Jason is the man
Did you talk to them yet?
Yes, I just got off the phone with them. They recommended I rotate 90* at a time and retest until vibration goes away. If that doesn't work to give them a call back.
Here's to hoping it works
Unfortunately I probably won't be able to get back to it until Saturday
Did you send them the pics to see if they considered that "normal"?
I think the vibration is in the U Joint Cup being damaged like it is. With that damage shown, I bet that the needle bearings are displaced somehow.
That just looks like debris or a metal shaving of some sort. I'm sure the OP can verify if it's an actual crack or not, but it doesn't look like it.
I never saw one like that when I worked at a shop that made drive shafts with Dana Spicer parts and we were a large distributor for them. That weakens the flange adapter at that point.
Just getting on, same thing they told me. Let me know if this doesn't take care of the situation. Sorry about the troubles brother.
I get that they would need to be balanced independently. But if a casting needs that much ground off it to balance, maybe they should look at the quality of the casting and revise it. This is what makes the difference between a quality part, and a shoddy part.
I just installed a DSS shaft on my car (my flange looks normal), and I'm not 100% happy with it (slight vibration at 100). So this is no surprise to me. I'm going to clock mine and see if it improves.
Same issue? Hopefully clocking it will work. Nothing is ever perfectly balanced so all we can hope to do it get the heavy spots in the drivetrain directly put of sync with each other in hopes of off setting the heavy spots
